How much HP can I get?
Old Jul 11, 2003 | 07:28 AM
Bigeye's Avatar
Bigeye
Default How many HP can I get?
How much HP you guys can get out of STOCK Engine of an Accord 1990 LX (A/T)?
Swap is considered but just want to try to keep the STK engine and simple.
I might even consider bolt-on Turbo Kits or whatever Bolt-on stuffs.
Its just my everyday car, nothing fancy.
If I need the real speed, I'll take the M3 out
Thanks
Old Jul 12, 2003 | 03:36 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Just about any power figure you're looking for is possible [think $$$]. The problem is that Automagic Honda Tranny. They just don't hold up well to much power over stock, their life severely shortens, and they're already shortlived enough with a price tag to make you cringe.
-Harry
AIM: NDcissive
Old Jul 14, 2003 | 03:24 AM
Bigeye's Avatar
Bigeye
Just enough to improving the pick up, perhaps 25 ~ 30 more HP.
This one will be my weekday ride to work (14 Miles round-trip).
Old Jul 14, 2003 | 03:45 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
get a torque converter will that help the life of the tranny i dunno but it will help you some as in getting the car to go faster
Old Jul 14, 2003 | 07:22 AM
1stGenCRXer
Well... a larger throttle body, some form of V-AFC [if you have VTEC, I can't remember], and an exhaust, header and intake should get you close to your power goals. More than that and you'll likely need to look at aftermarket cam options.
-Harry
AIM: NDcissive
Old Jul 14, 2003 | 08:38 AM
Bigeye's Avatar
Bigeye
Nope, the motor is none VTEC. I'll see if the EX's throttle body would fit. I'm getting the rear EX's suspension, so I can have a DISC on the rear.
Exhaust, Header and Intake will follow. Right now I need to drop it first, it's look like an Off-Road Accord at the moment.
Hopefully I can drop and replace all the shocks today after work. I have to go to a friend of mine... So, I can use his tools and lift.
I'll be fine with 30 more HP.
Old Jul 14, 2003 | 02:14 PM
1stGenCRXer
An AFC will help tune everything up for max performance, but yeah, I/H/E and a larger TB and some way to tune it is the minimum stuff you'd need for 30 ponies.
-Harry
AIM: NDcissive
Old Jul 22, 2003 | 11:23 AM
Si_Sean's Avatar
Si_Sean
ide stay away from a larger throttle body, you'de see more gains with a stock throttle body. Unless you you do decide to make it an FI system, then the more air flow the better.
Old Jul 22, 2003 | 01:35 PM
1stGenCRXer
The biggest downside of a larger TB is poor throttle response, and I normally do not suggest it as a beginning mod, but in the case of most F-series engines, the TB and intake manifold end up being choke points.
-Harry
AIM: NDcissive
Old Jul 25, 2003 | 04:10 PM
anthony1's Avatar
anthony1
you could port and polish the heads and go for a bigger bore
