civic b16a2 swap questions
Old Jul 8, 2003 | 07:40 PM
civic-style's Avatar
civic-style
Default civic b16a2 swap questions
I have a 95 Civic Dx 5 spd. I want to swap a b16a2 into it. I was wandering what I need to buy and what I could use from my stock car. Also is more difficult to swap a V-tec into a non V-tec. If you know of any sites or books that would make it easier, could you let me know.
Old Jul 9, 2003 | 08:47 AM
egzivic's Avatar
egzivic
MOST swaps come with the correct shift linkage and ECU. The motor mounts made need a bracket or two from different models. Also, you will need a throtle cable. I swaped a JDM B16A into my 92 HB and used Hasport mounts with 91 GSR rear mount bracket, 91 GSR Throttle cable. The wiring is not as difficult as everyone makes it out to be. You can use the harness that your car has now, you just have to add 4 wires. Using the plugs from your B16 add two wires for VTEC oil pressure (green 2-pin plug), one wire for the VTEC switch (next to the green pressure switch) and one wire for the knock sensor (under the intake manifold, above the oil filter). The VTEC oil pressure wire color blue goes to the ECU pin D6 and the black one goes to gound (I routed it through the harness and gounded with the harness on the Tstat housing). The VTEC switch (yellow/Green wire) goes to ECU pin A4. The knock sensor goes to pin D3.
Old Jul 16, 2003 | 06:14 PM
jeepxj66's Avatar
jeepxj66
interesting....92 was the first year for the US GSR? Where did you find parts for a 91
Old Jul 17, 2003 | 07:29 AM
egzivic's Avatar
egzivic
I worked at a Acura Dealership, so parts were not an issue. Besides Hasport helped out with what would work and what wouldn't. Axles were fun to locate too, but now you can get the axles with the swap, how times have changed.
