VTEC engagement activated swtich!HELP
Old Jun 24, 2003 | 07:00 AM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Default VTEC engagement activated swtich!HELP
Hey i've heard about MSD making an RPM activated switch and people using it for VTEC engagement, can anyone tell me what else i'd need for this and what site to get this from? thanks guys!
Old Jun 24, 2003 | 10:42 AM
crxb16er's Avatar
crxb16er
It's VTEC time! The most simple VTEC controller would be a toggle switch wired to the solenoid. But that would be rather inefficient. But if you're in a hurry, it'll let you test that the VTEC is working. You can design your own VTEC controller with a MSD rpm switch PN-8950 and PN-8671 which will give you a range of 4600-6800rpm to activate the VTEC.
Another low cost option would be the Autogage (by Autometer) ATM-2302 Tach with built in shift light. The shift light could be wired to trigger the VTEC solenoid, its infinitely adjustable from 1K-8K RPM and costs less than $80. See Matt's VTEC controller article at the Integra Performance Page for more info.
directly copied off this page http://hybrid2.honda-perf.org/tech/sohcvtec.html
i would suggest either getting the correct controller or doing the autolight suggestion instead of a toggle switch good luck
Old Jun 24, 2003 | 10:43 AM
crxb16er's Avatar
crxb16er
i have an autolight shift light and u just buy the pills when u want it to light up so all ud have to do is jump it off ur distributor wire and hook it up with the correct pill where u wanted vtec to engage.
Old Jun 24, 2003 | 04:20 PM
ZiviCase10287
RacinMasonC
i already have to autometer shift light but i wanted it for shifting so i could concentrate on the road during street races! but i guess i could use that, right now it has a 3,000rpm pill. theres 3 wires.. 12v switch, distributor, and ground i believe, where would it all go then? thx crxb16er for your help!
Old Jun 24, 2003 | 05:26 PM
CivicRacr's Avatar
CivicRacr
changine the vtech engagement without changin air/fuel ratio is pointless and could rob you of power if you engage it earlier or later than stock engagement point. the reson is when vtec kicks in at stock the ecu adjusts a/f at the point of vtec. so making come on early your messing up the a/f ratio. get a V-AFC to do this.
Old Jun 24, 2003 | 06:12 PM
ZiviCase10287
RacinMasonC
id get the pill kit to 4000-4900rpm and set it at 4800 rpm
Old Jun 25, 2003 | 07:01 AM
ZiviCase10287
RacinMasonC
can someone tell me where all the wires would go from the vtec soleniod for my autometer shift light??? please, FYI theres 3 wires. red, black, green.
Old Jun 25, 2003 | 07:20 AM
crxb16er's Avatar
crxb16er
umm ur talking about on the shift light? or the vtec soleniod? for the shift light its:
red 12 volt constant
black ground (chassis)
green off the distributor ill find out the exact wire to jump tonight when i take a look at mine, thats the wire ur gonna have to hook the sylenoid into also to get the power at the correct rpm.
Old Jun 25, 2003 | 07:41 AM
ZiviCase10287
RacinMasonC
i have my shift light all hooked up and its working with my 3K pill but i just want to know where the wire goes of the dist. wire to the solenoid? the green goes on the soleniod? which one, i have to wires off the solenoid. the one closest to the firewall or the radiator?
