GSR Swap
Old Jun 20, 2003 | 11:44 PM
Slacker's Avatar
Slacker
Default GSR Swap
I just had a gsr swap done in my 99 civic ex. Its a 96 jdm b18c motor. I have to run my computer on it temporarliy. Is that the reason it won't let me rev my motor past 5000rpm?
Old Jun 21, 2003 | 10:34 AM
crxb16er's Avatar
crxb16er
yah possibly something isnt correct with the rev limiter, but more likely ur not getting all the power u should because of incorrect air/fuel ratios, timing,etc that is programmed into the 99 ex ecu, id suggest getting the correct ecu for the engine ur running to not only get the power u should but also to avoid damage and complications with the gsr engine uve got.
Old Jun 21, 2003 | 04:25 PM
Slacker's Avatar
Slacker
Ya I ordered an OBD1 gsr ecu with the harness. I'll hold off on driving it till then. THanks!
Old Jun 21, 2003 | 06:54 PM
PHiZ's Avatar
PHiZ
BOOST GOD
hey bud, can you tell me what CELs you're throwing with that setup, I'm curious, it's probably easiest to go to an auto-store and borrow their code reader, cause I'm guessing you're throwing a bunch...
-PHiZ
Old Jun 21, 2003 | 08:37 PM
Slacker's Avatar
Slacker
-PHiZ
Not even going to bother... I'd prob max out the memory on the reader Hopefully this OBD1 ecu will help.
Old Jun 22, 2003 | 07:17 PM
incublinkus's Avatar
incublinkus
JDM Fan Boy
also, your computer isn't programmed to open the B18C secondary butterflies in the intake manifold...that would definately prevent the engine from revving up...
Old Jun 22, 2003 | 07:51 PM
PHiZ's Avatar
PHiZ
BOOST GOD
IAB opens around 7 grandish, if I recall. Vtec a litle over 5, I think.
there might be some missing sensors between the JDM/USDM ecu/computer, are you going same market for the ecu?
Like I don't think jap motors have the EGR solenoid, and maybe a knock sensor where USDM doesn't or vice versa...
-PHiZ
