problem with 5th gear on 00 si
Old Jun 19, 2003 | 06:46 AM
KaoticIllusionz's Avatar
KaoticIllusionz
Default problem with 5th gear on 00 si
i just got my 00 si at the begining of the month.its got 40,000 miles on it.a couple days after i got it it started to get hard to put into 5th gear or it would grind 5th gear.all of a sudded its starting to pop out of 5th.anyone have any idea what it could be?any help appreciated.
thanks
Old Jun 19, 2003 | 07:42 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
First off, check your tranny fluid level. That's the first thing that pops to mind as a potential cause, and it's pretty cheap to check/correct.
-Harry
AIM: NDcissive
Old Jun 19, 2003 | 02:29 PM
SI4life's Avatar
SI4life
I had a 99 ex that did the same thing in 3rd and the had to change the gear in it...but it was under warrent so it didn't cost me anything...but i would check the tranny fluid level and if thats ok then bring it to someone or do it yourself if you think you can.
