Questions on CEL Codes
Old Jun 11, 2003 | 09:35 PM
Scrub91DX's Avatar
Scrub91DX
Un-Registered User
Default Questions on CEL Codes
i was getting a check engine light everytime i drove the car so I Read the Codes off of my ECU and i got 3 different codes
Code 1 - Oxygen Content
Code 16 - Fuel injector
Code 17 - Vehicle Speed Sensor
Im guessing that by the Code 1 that i need to replace the O2 Sensor okay no problem, and that i need to replace the Fuel Injector also as for that i have 4 1990 Integra LS injectors would i be able to use one of these injectors to replace the single one on my car? and would the vss out of a 90 integra ls (manual tranny) work on my car (auto tranny)?
Any Help Would be Greatly Appriciated
-Matt-
Old Jun 11, 2003 | 10:09 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
one question....what kind of car are you working on?
Old Jun 12, 2003 | 12:00 AM
Scrub91DX's Avatar
Scrub91DX
Un-Registered User
91 Civic Sedan DX 1.5L Auto Trans
Old Jun 12, 2003 | 01:00 AM
silverstreakin
TRD japan ownerages
yeah#1 i would replace the o2
im not sure what to tell you about the injector. i would doubt a single off a set of 4 would be enough for youre entire engine...i would check around on that one
vss...look at it good. maybe pull off the plug and look at it. on my civic (96) it got corroded and a prong actually broke off...i hotwired it.. i would check for all that. you never know
hope some of that helps
