grinding in reverse....
Old May 30, 2003 | 01:14 PM
preylude99's Avatar
preylude99
Default grinding in reverse....
hey guys, on that 89 lude I bought..... when I put it into reverse, it tends to grind....I checked the tranny fluid and it was full, I havent driven the car yet so someone suggested it could be rust on the flywheel since it was sitting for a while and that it would go away when I drove it a while....the clutch is engaging because I can put it in first etc, just that reverse tends to grind, and reverse doesnt have a synchro, any suggestions? thanks....
Old May 30, 2003 | 01:58 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
before you put the car in reverse, bump it in first gear real quick - this will stop the input shaft from spinning and let the tranny mesh into reverse without grinding. I do this all the time with all stick shift cars, it's a good habit to get into.
Old May 30, 2003 | 02:00 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
Oh, and also check your clutch cable/adjustment, it might be too loose.
Old May 30, 2003 | 04:08 PM
preylude99's Avatar
preylude99
k i checked it and its ok, so yur saying there is no real fix to that, that I just have to put it into first then reverse if I dont want it to grind? hehe.....its not that I mind doing that, its just that if I sell the car the person buying it would probably be swayed away when they go to put it into reverse and it grinds....
Old May 30, 2003 | 06:11 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
If the clutch was ok before the car sat, then most likely it's rust on the flywheel - you can get rid of it by simply driving it for a while or if you want quicker results, you can slip the clutch a few times while you're in high gear on the road - but caution, you can glaze the clutch disc from too much heat that way if you go over board. If that doesn't fix it, you could also have a bad pilot bearing or a bad input bearing - this would usually cause the clutch to chatter as well.
