S2000 Engine in a Civic 96-00
Old May 27, 2003 | 07:17 PM
DragonLord's Avatar
DragonLord
Default S2000 Engine in a Civic 96-00
Do you think its possible...
I know with money anything is possible but can this work...
Old May 27, 2003 | 07:28 PM
Snoopy's Avatar
Snoopy
been there done that
like you said with money you can get it to work but why?
Old May 27, 2003 | 07:31 PM
DragonLord's Avatar
DragonLord
Don't Know just for the fun... I guess... :naughty:
Old May 27, 2003 | 07:44 PM
Level_7's Avatar
Level_7
You'll have to do _alot_ of custom work...its not even for FWD machines.
Old May 27, 2003 | 08:02 PM
DragonLord's Avatar
DragonLord
I know oh well will just buy a S2000 then heh...
Old May 27, 2003 | 08:11 PM
Snoopy's Avatar
Snoopy
sure take the easy way out
Old May 28, 2003 | 08:35 AM
jung4g's Avatar
jung4g
Asianalize your car
Default Re: S2000 Engine in a Civic 96-00
Yup,
get the tranny, ecu, and rear end as well. We'll just chop some metal here, weld some there, custom fabricate a new suspension setup in rear, rig up a new tubular front end, and
REAR WHEEL DRIVE CVCC2000.
Now while were at it, we could do a S2000 front end conversion and make a S2000 hatch :huh: or sedan ... Sick!!
Jung
Old May 28, 2003 | 09:49 AM
crxb16er's Avatar
crxb16er
yah it can be done, but ur gonna have to get custom mounts made, gonna have to reroute the rear differential to the back by customizing the underbody, gonna have to get a custom gas tank to get it out of the way, then ur looking at alot of work creating the rear wheel drive axles with assembly to fit the back end, will need really nice suspension system in order to handle all the weight on the nose of ur car and the new rear suspension, not to mention pretty much everything that comes out of the s2000, bigger fuel pump, custom air intake, etc. new custom exhaust. plus a ton of stuff i dont feel like naming cuz my head hurts, but id only suggest diong this if ur planning on making a show car, not a daily driver or even a drag car, ur better off just getting a strong block and turbocharging the sh!t out of it, and u'll save urself many thousands of dollars.
this guy built a crx with a crv+awd+turbo setup so nethign can be done
http://public.fotki.com/morgie/qsr/crx_gsr_awd_turbo/
Old May 28, 2003 | 12:52 PM
rev's Avatar
rev
If you can put a small block chevy in a vw bug then yes you can make that work. Just takes lots of time and even more money.
Old May 29, 2003 | 02:07 PM
qtiger's Avatar
qtiger
Yes. Prototype Motorsports is making a bellhousing which will allow an F20C (S2000) engine to be connected to a K series transmission. There are already companies who will mount a K series in an EK Civic, all you'd have to do is worry about soace and the driver's side engine mount.
