what are these springs on the header for?
Old May 26, 2003 | 07:57 PM
Snoopy's Avatar
Snoopy
been there done that
Default what are these springs on the header for?
this is the toda header btw
Old May 27, 2003 | 02:44 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
looks to be what is holding them together......
Old May 27, 2003 | 08:10 AM
qtiger's Avatar
qtiger
It's a slip-fit header.
Old May 27, 2003 | 02:04 PM
Snoopy's Avatar
Snoopy
can you go into detail?
Old May 27, 2003 | 04:21 PM
STOCK96civicDX's Avatar
STOCK96civicDX
I take care of my member
From the looks, those pipes will come out of the header if you remove the springs. so those springs are holding the pipes in. My motorcycle has 2 springs on the pipe (aftermarket) holding it onto the S pipe. I would guess that you can remove all the pipes from the header to ease installation....bolt it up to the head, then slip each pipe in one at a time. would be a hell of a lot easier than trying to snake it into the engine bay.
Old May 27, 2003 | 04:27 PM
Snoopy's Avatar
Snoopy
wouldnt it be more prone to leaking then?
Old May 27, 2003 | 04:31 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
No, those springs are pretty stout. it would take a lot of backpressure to cause the joint to leak. Another advantage to that style header is that the runner lengths can be tuned if the header is made to accept spacer pipes. If not, it's just for ease of installation/removal.
-Harry
AIM: NDcissive
