Mount ITR camchafts in a GS-R?
Old May 14, 2003 | 11:56 AM
clabbe's Avatar
clabbe
Default Mount ITR camchafts in a GS-R?
Hi..
The question is this..
I´m thinkinig of replacing my cams with the cams from the C5 engine because I´ll get them cheap from a friend!
But! Do I also have to replace the vaultssprings/vaults and more?
Or can I just mount the cams and drive?
Does the stock C1 vaultsprings/vaults handle the power of the C5 cams or will the engine fail???
Old May 14, 2003 | 12:15 PM
hlhiii's Avatar
hlhiii
you do not have to replace the valve springs. i would suggest a pair of cam sprockets so that you can fine tune the cams.
Old May 14, 2003 | 09:54 PM
clabbe's Avatar
clabbe
So the C1 vaultsprings can handle the power from the C5 cams without failing?
Old May 15, 2003 | 11:25 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You can get R intake valvesprings, and move your existing intake springs to the exhaust side.
Old May 15, 2003 | 05:34 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Clabbe, hows the weather in Stockholm right now? I'm going to Uppsala in a couple weeks.
Sorry for the thread hijaking.h:
Old May 16, 2003 | 05:07 AM
clabbe's Avatar
clabbe
Sun is shining!
Old May 16, 2003 | 09:53 AM
qtiger's Avatar
qtiger
I deleted a few of the offtopic posts. Let's try and keep it clean.
ITR cams will be OK with stock valvesprings if you use the stock GSR redline, not ITR redline.
Old May 16, 2003 | 10:37 AM
clabbe's Avatar
clabbe
So I shouldn´t rev the engine pass the GS-R redline?
But that would be almost impossible!
