fuel tank pressure sensor
Old May 13, 2003 | 10:42 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
Default fuel tank pressure sensor
help!!! any differences between a 96 lx to an ex? i got the rest of the problems with alleys car fixed... and even tweaked it a little....you can almost hear that sohc vtec enguage :lmfao: the throttle response on that thing will hurt ya thats for sure...last problem and ill have this thing done finally
any ideas? help me out here
Old May 14, 2003 | 11:37 AM
v4lu3s's Avatar
v4lu3s
whats a fuel tank pressure sensor?
Old May 18, 2003 | 10:30 AM
Evilkittie's Avatar
Evilkittie
sexygreencivic
:lmfao: exactly what it says its the sensor that controls the fuel tank pressure.
Old Jun 2, 2003 | 01:32 PM
silverstreakin
TRD japan ownerages
disregard my wifes flaming....any help on this?? im at a loss on this thing!
Old Jun 2, 2003 | 02:50 PM
TheRooster's Avatar
TheRooster
Former Senior Member
The regulator sits atop the fuel rail... and it controls the fuel pressure in the lines. Your fuel tank isn't pressurized. There's some other valves and such associated with the fuel system that have to do with smog, but nothing that would control pressure in the tank. Evaporative vapors, maybe... What's the problem you're having exactly?
Old Jun 2, 2003 | 03:30 PM
silverstreakin
TRD japan ownerages
code 91 fuel tank pressure sensor... i thought it was the gas cap...no dice. the only other thing i can think of is the fact that the sensor is leaking around the top on the tank making the car smell like gas...this is the last thing i can think of really....any ideas? btw this had a mini me swap 4dr lx to a d16y8
EDIT: yes its emissions
Old Jun 2, 2003 | 03:37 PM
qtiger's Avatar
qtiger
It's a pressure sensor for the evaporative emissions, but I have no idea if the parts are the same. Best way to find out would be call a dealership and ask if the #s are the same.
Old Jun 2, 2003 | 03:45 PM
silverstreakin
TRD japan ownerages
thanks!!
Old Jun 2, 2003 | 04:20 PM
crxb16er's Avatar
crxb16er
check ur charcoal canister, that is the most common reason for fuel smell inside the engine bay, or possibly the banjo bolt atop the fuel filter is leaking. tonight when i get home ill give u a run down of possible fuel components to check
Old Jun 3, 2003 | 06:44 AM
crxb16er's Avatar
crxb16er
alrighty now for the fuel smell neway, ur gonna want to check leaking fuel feed or return line, evaporative canister filter clogged, or fuel injector internal parts worn or fuel rail not connected correctly, or ur gas tank is just too full, pretty basic stuff but hey maybe itll help u. good luck
