92-95 Civic H22 swap questions
Old May 12, 2003 | 06:23 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default 92-95 Civic H22 swap questions
OK my Accord has an H22 in it which is getting a serious all motor build in it and will be sitting around the 12:1 compression ratio.
So heres my thought.
After its done and I set my goal of 13 seconds in the Accord with the engine I was thinking of getting a 92-95 Civ Hatch to swap this engine into...strictly track car....and placing a JDM H22 in the Accord for daily use again.
So what are the logistics of the H22 Civic swap? and what kind of possible times would be realistic from this setup?
Old May 12, 2003 | 06:53 PM
qtiger's Avatar
qtiger
Figure a .1 drop in 1/4 mile for every 100 pounds the Civic is lighter than your Accord. So, if you run a 13 in your Accord and the Civic you choose is ~800 pounds lighter, you'll be in the low 12s.
Obviously weight difference will depend on trim of the Accord and Civic.
Logistics? Pick up a set of motor mounts designed for the H22, and do your VTEC wiring if the Civic is nonVTEC.
Old May 12, 2003 | 08:10 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Uhh is there any cutting or anything of that nature I will need to do?
Old May 13, 2003 | 05:15 AM
v4lu3s's Avatar
v4lu3s
not if you buy the mount kit.
Old May 13, 2003 | 06:30 PM
ragerized's Avatar
ragerized
dc4 ownerages
yeah im thinking about doing a h22a swap on a civic hb.
so approx. how fast would this run with just the swap on a qtr mile?
and also, would a 18g turbo or a jackson sc yield more gain?
Old May 14, 2003 | 11:44 AM
v4lu3s's Avatar
v4lu3s
with a kinked fuel line and low fuel pressure i managed to stay with in 4 car lengths of a 13.1@108 camaro on a 20-100 roll....meaning that i should be in the mid 13s as is.
