Oil squirlters in B Vtec?
Old May 9, 2003 | 02:28 PM
WojtekG's Avatar
WojtekG
Default Oil squirlters in B Vtec?
Does anybody know how can I locate these parts in engine and what is it? I read somewhere that when doing LS/VTEC mod I should transplant these parts from VTEC block to LS block to secure proper oil lubrication of LS block.
Old May 9, 2003 | 02:36 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
All B18C blocks have them. They're at the bottom of the cylinders and squirt oil up under the pistons.
#14 in this pic:
Old May 9, 2003 | 03:20 PM
WojtekG's Avatar
WojtekG
Thanks, unfortunately I have B16A for LS/VTEC, so I assume that B16A doesn't have such squirters, does it?
How many squirters do I need. 4?
Old May 9, 2003 | 07:38 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I think some of the B16 blocks had them too. You would need 4, one for each cylinder.
Old May 25, 2003 | 01:09 PM
WojtekG's Avatar
WojtekG
I've tried to install these squirters from B16A block, but it seems that there are not oil lines in B18B block from my LS. Is there any trick to make them work, or I have unusual version of B18B block.
Maybe You know what additional modification I should do to make these squirters work.
Thanks in advance
