Throiwing my first code!
Old Jul 1, 2002 | 07:40 AM
white lightnin's Avatar
white lightnin
Default Throiwing my first code!
Im throwing my first code since my swap. Nto sure what it is. This what confuses me:
In the past when I have had a code the CEL comes on and stays on. Even if I fixed the problem (knock sensor) the code stayed on til I reset the ecu. Now I am getting this code that comes on while Im driving and goes away once I turn off the car. When I start it up it wont come on again for a while. Tried jumping the ecu and I get nothing.
Ok I disconected my header to fix it up when swapping brakes and suspension. in the process my friend stripped the pins from the O2 sensor harness. THought we put them back in right but now this code. Also removed the map sensor and secondary dashpot for certain reasons.
Can you guys help me:
Sond like the O2 sensor?
If so anyone have a wiring diagram?
Proper ecu jumping procedure just to double check myself?
Tahnks, Robert.
Old Jul 11, 2002 | 01:11 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
check the code, whats code is it throwing???
Old Jul 11, 2002 | 01:19 PM
98EX's Avatar
98EX
Insane Wierdo
It sounds like what happened when my O2 sensor(primary) was going bad, all I had to do was turn thecar off and the CEL went away for a bit and then would come back on.
Old Jul 14, 2002 | 07:47 PM
EG6's Avatar
EG6
we have a code list on our site @
www.161822.com
Hope it helps
white lightnin
92+ Civic/EL & Del Sol
6
Jul 1, 2002 10:47 AM
