how hard is swapping for a 1st timer?
Old May 1, 2003 | 08:35 PM
EddieK's Avatar
EddieK
Default how hard is swapping for a 1st timer?
i was wondering if it would be very hard to swap a 99 integra LS motor into a 93h/b. i want to do it myself instead of having some nutt overcharge me on doing it. but.... is it very hard? what could i use to guide me through?
Old May 1, 2003 | 08:36 PM
Snoopy's Avatar
Snoopy
been there done that
what could you use to help you?
www.helminc.com
Old May 1, 2003 | 09:47 PM
preylude99's Avatar
preylude99
yea, it should be very helpful, hopefully you have another car to drive in the meantime so you can take things slow and not miss anything....
Old May 2, 2003 | 07:42 AM
stevieteg's Avatar
stevieteg
Default Re: how hard is swapping for a 1st timer?
Wasen't too hard for me. Car was down for about a week. Everthing worked out. If you have the tools and resources go for it. Good, helpful friends will be needed too. A shop with charge you an arm and a leg, plus they will keep your core. Make sure you map out a plan and don't forget anything. I recommed you change your timing belt and water pump before you do your swap. New clutch would not be a bad idea either. I am in the middle of my next swap now...
