owned at the State ref, what a suprise :\
Old Apr 29, 2003 | 11:00 AM
GReekbro's Avatar
GReekbro
Alexander the Great !
Default owned at the State ref, what a suprise :\
well the Visual part of the test went fine, welp minus the p28 ECU i was running (couldnt find my friend to get my p72,damn't
Comprehensive Visual Inspection: TAMPERED (ecu)
Functional Check: PASS
Emissions Test: GROSS POLLUTER :\
now i failed the emission test on high HC and CO numbers, take a look...
Idle Emission Results
HC #'s
Max- 100
GP-250
MEAS 443
CO #'s
MAX- 1.00
GP- 2.50
MEAS- 1.26 (idle-1036rpm & 1.78 MEAS 2500rpm-2588rpm)
[MEAS = amount measured] --- [GP = Gross polluter limits] --- [MAX = maximum allowable emissions]
now what could cause these high HC and CO emissions? can anyone analyze for me? i guess time to go get a diagnosis, any smog station will help me correct?
Thanks In advance ppl.
Old Apr 29, 2003 | 02:07 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
What kind of cat are you using? Stock Civic one, GS-R one? Was the P28 you were using a stock P28 SOHC VTEC ECU or was it chipped for a DOHC program (Skunk2, JUN ...). If it was chipped, that might be it. Those programs tend to run incredibly rich to compensate for a pair of extreme cams so that might be why your so off. See if you can find a stock P72 and retest. Also, if possible, try to keep the your engine/cat warm before they do the sniffer test. Cats take a while to heat up and work properly. I'm sure they take that into account while testing (I'm in PA and I have zero emissions testing) but something to try. Seeya.
Old Apr 29, 2003 | 03:37 PM
R92680's Avatar
R92680
hhah told you to get the right o2 sensors and the right cat i got the the same scores on mine if you need me to show you the scores before and after each i have them the 02 sensor will cut it down by half if use the factory gsr o2 sensor and the cat by a third it took me three times to pass first with the cat and second with o2 sensors
Old Apr 29, 2003 | 03:51 PM
R92680's Avatar
R92680
-----------------HC--- CO%
-------%CO %o2 max ave max ave meas
15mph 14.7- 0.1- 60- 12- .53- .05- .03-
25mph 14.7- 0.2- 43- 5- .51- .02- .01-
NO(ppm)
------max av meas
15mph 1011- 74- 7-
25mph 871- 78- 4-
results
15 mph pass
25 mph pass
Old Apr 29, 2003 | 04:04 PM
R92680's Avatar
R92680
dude let me know next time ill let you barrow my 95 p72 with a stock program and ill rechip it when you get done
Old Apr 29, 2003 | 04:57 PM
dubcac's Avatar
dubcac
I
Try a different cat. Were you using a DC header by chance?
Old Apr 29, 2003 | 06:59 PM
GReekbro's Avatar
GReekbro
well fellas, i knew i was gonna fail....why? because the ecu IS indeed chipped by the Mugen prog...
BUT, my question now is, can that ECU, ALONE cause all those high numbers in both HO and CO ?
and you bet i tried frying that cat, the trip to ESCONDIDO from the middle of SD is like 30 minutes
i guess i'll just have to research on the net about what causes those high numbers, the cat is fine, had it recently replaced from a muffler shop, and yes i have the correct 02 sensor on it as well....
Thanks for the replies fellas
Old Apr 29, 2003 | 07:05 PM
R92680's Avatar
R92680
it could, maybe not all of it thats pretty high but it could cause a huge change in how the motor reads at lower rmps duing the 15 mph test but not so much in the 25mph because the mugen program is the riches program i know as far as fuel might cause the cat and o2 to act up
