I have free access to...
Old Apr 23, 2003 | 10:18 PM
sinsatan's Avatar
sinsatan
Default I have free access to...
a Volvo 760 turbo. All turbo parts are there. I guess my question is...... Is it possible to use any of these parts on my 91 CRX Si?
Old Apr 24, 2003 | 07:29 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You could probably use some but not all of the parts. The exhaust manifold obviously isn't going to bolt onto your car, but you can probably use the turbo, blowoff valve and intercooler (although my guess is that it's pretty small).
Depending on what exhaust housing the turbo uses you may be able to use one of the readily-available aftermarket exhaust manifolds out there like Drag, RevHard, etc that are flanged to mate to a T3 exhaust housing. Alternatively you can take the upper portion of a CRX HF/Civic Std exhaust manifold and modify it to mate up to your turbo if you've got some fabrication skills.
From there it's just a matter of making sure you have enough fuel going into the motor to compensate for the extra air.
Old Apr 24, 2003 | 04:42 PM
sinsatan's Avatar
sinsatan
Cool man. I will definately get that stuff out before we take the volvo to the scrap yard. And thanks for the info.
