question regardin timing...
Old Apr 20, 2003 | 08:23 PM
accordtuner's Avatar
accordtuner
Banned
Default question regardin timing...
hi everyone,
have a ? regarding timing, how do you know if your timing is off? and how do i go about checking this? my 97accord 2.2 is backfiring and its nothing ignition wise, ive changed and checked everything (plugs,cap,rotor,coil,dist, etc) jus wana know what are sum of the symptoms of bad timing and how i can go bout fixing this.
thanks,
m
Old Apr 21, 2003 | 02:13 PM
doctorsohc's Avatar
doctorsohc
I HATE SCAMMERS!!!!
is it backfiring through the exhaust or intake? could be running to rich/ or lean out of many reasons (bad fuel pressure reg, intake or exhaust valve, timing to advanced or retarded, bad igniter or coil, valve clearance too tight, vac leak, egr valve stuck) what do the plugs look like? Does it only happen under load? U can set timing by checking for marks on timing belt cover falling in between marks on crank pulley or on some older cars pulling out the inspection plug on side of auto trans. Engine has to be warmed up at idle for doing this. Also check cam timing.
Old Apr 23, 2003 | 01:14 AM
MikeR's Avatar
MikeR
unless timing belt is stretched beyond belief,(which would definately need attention sooner than later) the timing shouldn't be the problem, unless serious wear on some components or unless somebody's been wrenching around under the hood your motor shouldn't ever be out of time, that's not really a maintenance check, like i said unless a component is worn badely, t/b or t/b tensioner, but say you had the t/b off, as far as timing it you would have to match marks on cams, and crank, as well as marking #1 at tdc. and if dist. was removed it's time to get the timing light out
Old Apr 23, 2003 | 01:33 AM
drift's Avatar
drift
Flaccid Member
it's OBDII. the ECM controls timing 100%. if timing is off, you have to replace the ECM.
if you're getting a CEL, have it scanned to find the source of the problem.
Old Apr 23, 2003 | 08:04 PM
accordtuner
Banned
no cel at all. i jus replaced the ecu recently cuz my car would start intermittenly, it fixed the prob. even tho it was backfiring too. its runnin way too lean rite now..
