is there a dif????
Old Apr 10, 2003 | 01:01 PM
Import_Del-Sol's Avatar
Import_Del-Sol
Default is there a dif????
is there a dif between the b18c gs-r and the b18c type-r?
Old Apr 10, 2003 | 01:20 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
in short, yes.
Old Apr 10, 2003 | 01:25 PM
Teg711's Avatar
Teg711
Purge This...
Originally posted by inspyral
in short, yes.
i was tempted to write the same thing...
isn't it basically the pistons?
try a SEARCH i'm pretty sure various related topics have been covered...
Old Apr 10, 2003 | 01:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
pistons, head, cams, valvesprings, intake manifold, tranny, shift linkage(R ones are bronze), axles(99 spec R uses larger diameter axles)
That's off the top of my head, I'm sure others will chime in with other differences.
Old Apr 10, 2003 | 01:36 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
c'mon inspyral...
The blocks are basically the same, as are the cranks and rods. The Pistons are different (higher dome), in the bottom end, that is pretty much the only difference. Up top everything is different, including the head casting. The head is cast from the same mould as the B16 and given a mild polish and valve job from the factory. The Entire valve train is more high performance, right down to the Lost Motion Assembly, up through the springs, retainers, and down to the camshafts. The intake manifold is of a totally different design. The GsR has a two stage electronically activated for high rpm and low rpm. The type r has a higher performance intake manifold designed with one set of runners for high rpm applications. It also has a little bit of a different header setup in japan featuring a 4-1 design as aposed to the traditional 4-2-1
Old Apr 10, 2003 | 02:04 PM
Import_Del-Sol
kool so i guess i will go with the type-r... what would yall go with?
Old Apr 10, 2003 | 02:10 PM
Teg711's Avatar
Teg711
Purge This...
well what do you want done to it, forced induction? nitrous? normally aspirated?
Old Apr 12, 2003 | 06:58 PM
Import_Del-Sol
turbo and intercooler-forced induction
Old Apr 12, 2003 | 09:40 PM
Teg711's Avatar
Teg711
Purge This...
then you'll want lower compression heads which the gsr has(well at least in comparison to the type r)
Old Apr 12, 2003 | 11:05 PM
SEK SEE's Avatar
SEK SEE
Last i checked Type R crank was different than GSR crank...
Lower compression heads that the GSR has? Actually last i checked the GSR had smaller combustion chambers than the Type R head, ... . .I think you mean the GSR pistons have less domage than the Type R . . ..
