counter balance belt
Old Mar 21, 2003 | 06:23 PM
preylude99's Avatar
preylude99
Default counter balance belt
hey, i have a 99 lude, base, 5spd, and got done doing the timing belt, tensioner/bearing and some other stuff, was a lil tough but got everything done alright, the thing is, I think I tightened the balancer belt a lil too tight but it still has good slack, but I can hear it a lil bit, is this something to worry about or will it eventually loosen up?
Old Mar 21, 2003 | 06:29 PM
AwwsChwA's Avatar
AwwsChwA
If you can tell that it's a little too tight, loosen it. It's never a good idea to leave a belt excessively tight. It will cause premature wear, accelerate belt stretch, and, well yea, you get the picture. So yea, if you can tell it's too tight by the sound it's making, that's the belt trying to tell you it needs to be a little looser.
Old Mar 21, 2003 | 06:41 PM
preylude99's Avatar
preylude99
well i know it should be a lil looser, but the balancer belt has a lot of slack to begin with, even when its making this sound....
Old Mar 21, 2003 | 07:25 PM
preylude99's Avatar
preylude99
also, the counter balance belt seemed to have plenty of slack, and the timing belt's slack is controlled by the auto tensioner, so what Im thinking it could be is the outer belts (power steering/alternator) belts could be a lil too tight.
Old Mar 21, 2003 | 07:41 PM
drift's Avatar
drift
Flaccid Member
if you have an autotensioner, then the internal belts will be fine the way they are.
you pretty much figured it all out on your own.
Old Mar 24, 2003 | 06:54 PM
wadzii's Avatar
wadzii
fear the dark side
rip the balancer belt out.. you dont need it and its good for about 12 hp.
Old Mar 24, 2003 | 08:16 PM
honda530's Avatar
honda530
www.HondaShowOff.com
ahh mine has been doing the same thing making a noise. I had my balance belt and timing belt done and the guys told me it would go away but it hasnt. Its good to know that I can now tell them whats wrong.
Old Mar 26, 2003 | 09:52 AM
preylude99's Avatar
preylude99
hey honda, yurs makes like a "woooo" sound at light revving in neutral like mine? cause mine didnt make it before, I also asked the dealer and they said on my motor the h22, the Tbelt follows a tight pattern by the bottom and that the grooves on the belt need to get worn in, an that it will go away, I will give it some time and see, its not a prob, jus annoying, what is your situation like? an what motor is this on?
