Obd2->1 B18c1 ??
Old Mar 21, 2003 | 03:14 PM
CivOnDubs's Avatar
CivOnDubs
Default Obd2->1 B18c1 ??
If I had a OBD2 gsr motor and I wanted to change it over to a OBD1 gsr motor what do I need to do ?
I'm guessing just a new distributor, and wiring harness?
Old Mar 21, 2003 | 03:30 PM
CivOnDubs's Avatar
CivOnDubs
Anyone know specifically what won't plug into a OBD1 gsr harness on an obd2 gsr motor.......
Old Mar 21, 2003 | 07:25 PM
flappy188's Avatar
flappy188
O.G. SON!
i think the o2sensor and a crank sensor???????like i said think but i really dont know! ask Q tiger!
Old Mar 21, 2003 | 07:40 PM
drift's Avatar
drift
Flaccid Member
you'll need a P72 OBD I ecu and an OBDII to OBDI conversion harness.
Old Mar 21, 2003 | 07:44 PM
qtiger's Avatar
qtiger
Wait... are you trying to put an OBD2 engine in an OBD1 car or change an OBD2 car to OBD1?
Stuff that won't plug in: Crankshaft speed fluctuation sensor. That's it.
Old Mar 21, 2003 | 08:37 PM
CivOnDubs's Avatar
CivOnDubs
yeah, im trying to put an OBD2 motor in an OBD1 car....what conversion harness and where do you buy it ???
Old Mar 21, 2003 | 10:19 PM
qtiger's Avatar
qtiger
Forget about it. Plug it into the OBD1 car with the OBD2 harness. Extra stuff just won't be pinned.
Old Mar 22, 2003 | 08:39 AM
CivOnDubs's Avatar
CivOnDubs
i'm surprised they didn't change any wires around in those plugs ? I was afraid they would plug in but certain wires went to the wrong place....
Old Mar 22, 2003 | 10:14 AM
drift's Avatar
drift
Flaccid Member
oops. my bad. didnt realize that it was concerning a motor.
swap the engine wiring harness as the plugs between the engine harness and firewall wiring harness are different.
i dont know if the B18C changed the timing (CKP, TDC) sensor locations from the distributor to the crank. if so, the easiest way to bypass this is to get an OBD I dizzy. if you cant, the OBD II timing sensors can still be read by an OBD I ecu... so you can just extend the wiries to reach the TDC and CKP sensors on the front of the motor.
Old Mar 25, 2003 | 09:23 AM
CivOnDubs's Avatar
CivOnDubs
wow, so converting a OBD2 GSR with the stock harness, is just merely extending 2 sensors and plugging the rest in with the OBD1 harness.....?
