Intermitant idle 91 Legend
Old Mar 19, 2003 | 07:44 PM
Amdy T's Avatar
Amdy T
Default Intermitant idle 91 Legend
replaced IAC valve, (Idle Air Control), Fuel Filter, Temp sensor and still idles up and down after it gets hot. seems to only do this when its in park or nuetral. stops when in drive.
Any ideas?
Thanks a bunch!
AJ
Old Mar 19, 2003 | 08:30 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Are you sure you don't have a vac leak or air in your cooling system?
Old Mar 19, 2003 | 08:36 PM
Amdy T's Avatar
Amdy T
How do I check for air in the cooling? Yep, I will check for vacum leaks too... it almost seems like it loads up.. when it starts to idle up and down, I rev the engine and let go and then it wants to stall. Then takes its time in re-starting but again idles intermitant.
Thanks!
AJ
Old Mar 19, 2003 | 09:52 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If you want to bleed the air out of your cooling system, the simplest method I know of is to run the engine with the radiator cap off and the heater blasting full-hot. This will circulate any air that may be trapped in the heater core and you'll probably see it bubbling at the radiator filler neck.
Old Mar 20, 2003 | 01:38 AM
Dave C's Avatar
Dave C
It could be the fast idle valve, but since that is temperature controlled I'd bleed the cooling system first. On the upper coolant neck you'll see a bleed bolt (kinda looks like a grease fitting). Crack that open and bring the engine up to operating temp. When no more bubbles come out your done.
The fast idle valve is on the back of the intake and a b!tch to get at. Suggest investing in a Helms manual.
Old Mar 20, 2003 | 06:10 PM
Amdy T's Avatar
Amdy T
Thanks erveryone! I will try your suggestions tomorrowand let ya know!
