injectors.
Old Mar 19, 2003 | 04:47 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default injectors.
Will mitsubishi injectors work with my b16? More specific, http://cgi.ebay.com/ebaymotors/ws/eB...category=33554
will these injectors be better than my stock ones?
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Mar 19, 2003 | 05:13 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Your stock injectors are already 240cc.
Old Mar 19, 2003 | 08:28 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I do believe those are peak and hold, so unless you have a resistor box and OBD-I style injectors clips, they won't work, and your stock injectors are 240cc, as was pointed out.
Old Mar 21, 2003 | 11:04 PM
Import-Tooner
skoooooie!
For some reason I thought they were lower cc's. What injectors would you recomend with all motor setups? I was going to go with a ls/vtec type motor but $ became short so I finished my b16a. (modded of course)
SKOOIE!!!
Old Mar 22, 2003 | 09:13 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You can look for some 280cc Prelude injectors. The largest you can go on a stock ECM is about 310cc. I would run the stocks until you're sure you need more fuel and have a way to tune your fuel map.
Old Mar 22, 2003 | 08:14 PM
seth90dx's Avatar
seth90dx
On this note, Im building the piss out of a DOHC ZC... Its got an 11.16:1 CR and a 62mm TB with a modified Intake Manifold (Moded by Endyn for better airflow) I will be adding a 55-75 ZEX nitrous kit... What do you guys think I should be using? Also I will have a ZDyne Gold PM7.
