Stock timing setting?
Old Mar 19, 2003 | 08:02 AM
DRTHV8R's Avatar
DRTHV8R
Default Stock timing setting?
I have a 92 ex civic, I had to change my distributor, and now i need to set the timing. Does anyone know what it is suposed to be set at?
Thanks in Advance
<url:http://www.cardomain.com/member_page...page_id=292645[/url]>
Old Mar 19, 2003 | 09:18 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I believe factory timing is 18 degrees advance at idle.
-Harry
AIM: NDcissive
Old Mar 19, 2003 | 09:25 AM
Christian's Avatar
Christian
Default DRTHV8R
Hey big BALLER!!!!
You don't even know stock timing for your car and you can comment on the price of seats that are worth as much as your POS.
Next time keep your two cents out of others threads if you have nothing good to say
BTW stock timing is 16 btdc
Old Mar 19, 2003 | 09:29 AM
1stGenCRXer
Originally posted by Christian
Hey big BALLER!!!!
I sure hope for your sake you're not talking to me.
-Harry
AIM: NDcissive
Old Mar 19, 2003 | 09:36 AM
Christian's Avatar
Christian
Why would you even think that? You don't know me nor do I know you. Chill out dude
Old Mar 19, 2003 | 09:39 AM
1stGenCRXer
Yeah, I just did a search on your threads, so I know the story now.
Just keep posts in this forum tech related and we'll get along fine, ok?
-Harry
AIM: NDcissive
Old Mar 19, 2003 | 02:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The "big ballers" use a timing light to set their ignition timing, and the stock timing increments are marked on the crank pulley. The white mark all by itself is TDC, the other three marks that are close together are stock timing +/- 2 degrees. Allign the middle of the three marks with the pointer on the block and tighten the distributer down. Done.
Old Mar 19, 2003 | 05:52 PM
Christian's Avatar
Christian
Inspyral is absolutely correct.....let the engine idle then set the timing light to 16 and turn the distributor until the center white mark is aligned as noted above
