rainbow rod bearings :( part #'s?
Old Mar 6, 2003 | 01:29 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default rainbow rod bearings :( part #'s?
so i am trying to get my rod bearings. they are for a 1st gen b16. 3 of the rod bearings are colored red and have a part # of 9J26K on them and the last one isn't colored. the # on it is 9J27L. does anyone know what color that would be? Or maybe where I could find out?
I am pretty sure the motor is from a teg too. I called the acura dealer and they are trying to find something for me.
Thanks
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Mar 6, 2003 | 06:56 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
There should be a number stamped on your rod, and a letter on the crank which will help determine what size bearing you need. For example, a red bearing would mean that your rod is stamped with a 1, and the crank with an A or an I. If you can tell me the number on your rod, and the letter on the crank corresponding to that rod, then I can tell you what color bearing you need. If these are aftermarket rods, or if you're not sure which cylinder the odd bearing is from, then you'll probably have to check the clearance with plastigauge and figure out what bearing you need.
Old Mar 8, 2003 | 10:57 PM
94civicEX's Avatar
94civicEX
I got worms.
Chase...you planning on responding :slap:?
99 Integra GSR
06 TSX
duck squad member #00003
