Canton Racing fuel filters
Old Mar 6, 2003 | 08:18 AM
qtiger's Avatar
qtiger
Default Canton Racing fuel filters
Thought I would let you know... Canton Racing just released an OEM-fitting fuel filter replacement with 1 micron filtration.
OEM banjo fitting on one side, OEM 14mm flare on the other. It's about double OEM height, but fits the stock bracket perfectly. :thumbup:
Old Mar 6, 2003 | 09:31 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Sweet, how much is that piece? Their cartridge oil filters are nice too.
Old Mar 6, 2003 | 12:25 PM
qtiger's Avatar
qtiger
$80, and uses a reusable element like all their other fuel filters.
Old Mar 6, 2003 | 01:09 PM
qtiger's Avatar
qtiger
I lied. The inlet is a 14mm flare... which is OEM as well.
Old Mar 6, 2003 | 07:47 PM
qtiger's Avatar
qtiger
This just in... thread pitch on the banjo bolt is incorrect. :madfawk:
Old Mar 6, 2003 | 07:49 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
They don't include a banjo bolt?
Did they use NPT threads or something?
Old Mar 6, 2003 | 07:51 PM
qtiger's Avatar
qtiger
Nah it is supposed to be OEM banjo bolt, using the one from my B&M kit. NPT tapped head so I can include the gauge. Fits in a Carquest fuel filter, so it's not my bolt.
The pitch is real close, I can get say... 2, 3 threads in before it crossthreads.
I was hoping to have the throttle bodies on this weekend. :happysad:
Old Mar 6, 2003 | 09:04 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You can always run a $14 OEM filter in the meantime
Old Mar 7, 2003 | 09:06 PM
qtiger's Avatar
qtiger
The oem filter um... doesn't fit. :naughty:
I went to a place called Detroit Flexible... www.hosenow.com
They've got everything under the sun, adapted all my stuff to -6 AN with a handful of fittings. Came out to $35 for all required fittings. Steel braid going on tomorrow.
