Putting head back together need help
Once again slow-n-low, you find a way to sneak in a negative comment. I do have knowledge of honda/acuras. Hence, why im doing it myself. I do not turn my workload on over to someone else simply because of 2 problems. Also, for your information, I have checked the oil and there is no mix of the two. Therefore, the gasket is not causing my motor to overheat. As I had indicated earlier, they are two seperate problems. Please do not reply to my posts.
