Transmission case
Old Feb 15, 2003 | 12:58 PM
BabyGirl ITR's Avatar
BabyGirl ITR
Killer B
Default Transmission case
i have a '99 jdm itr engine and my transmission case is leaking from a hairline crack by one of the bolts. i need some info on whether or not it can be welded or where i can buy a new case
Old Feb 15, 2003 | 07:28 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
If you want to take it somewhere to get it welded, make sure they have a TIG welding machine. Or you could just fill it full of JB Weld, that would work, and be the cheapest.
Old Feb 15, 2003 | 07:43 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I agree, I think JB weld would do the trick, but I'd drain the tranny and be sure to clean it up as best as you can before applying the JB. JMO.
Old Feb 16, 2003 | 08:26 PM
BabyGirl ITR
Killer B
ok, i'll try the tig welding because i've tried the jb weld and it didn't work. thanks for the help
Old Feb 21, 2003 | 06:35 AM
mrmike's Avatar
mrmike
i'd just get a new case. i've had problems like this and its a bit**
Old Feb 21, 2003 | 10:02 AM
BabyGirl ITR
Killer B
where did you buy your case? and aprox how much cost?
