what is a flex pipe?
Old Feb 9, 2003 | 12:03 AM
Snoopy's Avatar
Snoopy
been there done that
Default what is a flex pipe?
i've heard of people putting flex pipes in their exhausts but i have no idea what they are or what they're used for. :dunno:
Old Feb 9, 2003 | 06:36 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
It's a braided or spiraled steel section that can be bolted or welded into an exhaust system. The purpose of it is to maintain a leak-free exhaust system while accounting for engine movement that usually occurs in higher output applications.
Here's an example of the braided style:
And here's a shot with both styles in one photo:
-Harry
AIM: NDcissive
Old Feb 9, 2003 | 12:14 PM
pSiRacer92's Avatar
pSiRacer92
Banned
my car came stock with a flex pipe i thought all cars did
Old Feb 9, 2003 | 02:33 PM
1stGenCRXer
Not all cars. Most just come with a spring and donut gasket joint that combines the exhaust manifold and the under-car exhaust system back to the rear bumper.
-Harry
AIM: NDcissive
Old Feb 9, 2003 | 07:00 PM
-KangaRod-'s Avatar
-KangaRod-
Captain
so will things break if you don't use one?
Old Feb 9, 2003 | 08:40 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If your engine vibrates a lot, that vibration will get transmitted tot he exhuast, and it may rattle. I don't have a flex section, and my downpipe goes straight to my cat with no donut gasket or anything, and it's been fine for over 2 1/2 years. My engine doesn't really vibrate that much though, since the urethane mount inserts hold it in place pretty well. I think more of my engine vibration is transmitted to the chassis thru the mounts than thru my exhaust. If your engine moves around a lot, get a flex section.
Old Feb 10, 2003 | 12:39 AM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
I had my downpipe crack when I eliminated the flex joint.
Old Feb 10, 2003 | 04:57 PM
Slow-N-Low's Avatar
Slow-N-Low
What's that smell?
You need a flex connection if you bolt the exhaust system to the car. That includes pretty much any transverse motor setup, unless you're using solid motor mounts & torque strap mountings (read: "not for street use"). Don't confuse braided flexpipe with the cheap corrugated type! Corrugated is for half-assed installs, and can't handle continuous flexing. Use the braided kind.
