idle adjustment
Old Feb 6, 2003 | 04:11 PM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
Default idle adjustment
you all know sgc and who i am but anyway let me shoot this at ya guys
the moron that put the d16y8 in her car played with the idle air adjustment screw. the car has horrible idle problems now and i was wondering on some procedures on adjusting it correctly
on a different note does anyone know if the fuel tank pressure sensor is different on lx-ex civics 96-97?
Old Feb 6, 2003 | 06:43 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The idle speed setting from my Integra Helms manual (should be basically the same for you):
http://webpages.charter.net/mrfatbooty/pics/idle_1.jpg
http://webpages.charter.net/mrfatbooty/pics/idle_2.jpg
Old Feb 6, 2003 | 09:29 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Mikey's instructions are pretty much what it says in the 96-00 Civic Helm's.
D16Y8 idle speed is:
670 +/- 50rpm for a 5sp and
750 +/- 50rpm for an AT
Old Feb 7, 2003 | 03:21 AM
silverstreakin
TRD japan ownerages
sweet thanks guys....any clue about the tank pressure sensor?
Old Feb 7, 2003 | 11:48 AM
preylude99's Avatar
preylude99
the sensor should be the same but double check just incase im wrong, what is the problem with the idle, too high, too low, fluctuating?
Old Feb 8, 2003 | 12:49 PM
silverstreakin
TRD japan ownerages
just really unstable idle....car shakes like **** when it drops to idle speed....and generally itll idle at like a grand....once in a blue moon it actually goes down to the correct speed and when it does it just doesnt seem right
anyone know what the computer does if you take the secondary O2 sensor out of the exhaust and just leave it dangling? the moron that swapped the engine just left it out cause of the header. he said it would richen it up just a little but i really think it is too much i mean wtf a 1/4 tank to go across town
Old Feb 9, 2003 | 08:50 PM
preylude99's Avatar
preylude99
definitely too rich, did you check the spark plugs to see how rich it was running? also, you can get a set of cheap spark plugs to run in there for like a week or so, then take them out to see how rich/lean the car is running..... if the car vibrates when the idle drops too low, than that is normal, any car will shake when the idle is too low, but if it does it at like 1K it could be that a number or things got carbon build up from running too rich, how long has she been driving the car around like this?
Old Feb 10, 2003 | 06:35 AM
silverstreakin
TRD japan ownerages
quite a while actually...she drove it to dallas:wtf: i have found some of the problem though...the primary O2 is shot along with the vss. seems no one keeps O2s for these damn cars around here...im gonna go to honda today and see if they might have one
its not running rich enough to gas foul the plugs...i know that much, but still i think that is why the last engine blew the cyl got gas washed from this thing running rich
any clue on the fuel tank pressure sensor in doing a swap from lx-ex engine?
