Ls/vtec??
Old Feb 6, 2003 | 06:21 AM
hyperlite's Avatar
hyperlite
Default Ls/vtec??
ok ive been hearing about this motor, how it has the low end of the LS and the top end of the GSR. what is this engine compared to b18c and b18c5? ...and does this engine pass smog? does it just look like a normal gsr/ls, why wouldnt it pass
Old Feb 6, 2003 | 10:57 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If you're asking about the nuts and bolts of this setup, do a search, it's been covered many a time. If you're looking for dyno comparisons, check here:
http://www.importreview.com/dyno.html
No, an LS/VTEC will not pass CA smog. If you go to a ref, they'll look at your B18A/B block and they'll know it didn't come with a VTEC head. A little more snooping, and they'll see the oil line coming off the back of the block and you will not pass the visual. As for actual emissions, that shouldn't really be a problem as long as your smog equipment is in good working order, and the cat is properly warmed up before you roll into the smog station. If you go to a typical smog station, they may not notice that it's an LS/VTEC, but since smog stations are getting stricter nowadays, they might take one look at it and tell you to go to the BAR ref. The BAR ref will definitely know about LS/VTEC, and you will not pass.
Old Feb 6, 2003 | 11:02 AM
hyperlite's Avatar
hyperlite
thanks, thats what i wanted to know
