Air Fuel Ratio Tuner
Old Jun 22, 2002 | 09:39 AM
AFguy's Avatar
AFguy
Thank you for your responses. You are right, there appears to be some interesting obstacles on this path...
As for working perfectly, I meant that it works on an electronic bench and on a engine with a simplified ecu (no OBD II).
Looks like I may need to go back to the drawing board...
Old Jun 22, 2002 | 10:49 AM
qtiger's Avatar
qtiger
Originally posted by jdmcrx89
Also the DIY wideband will work with HONDATA'S Rom Editor just like the Motec unit.
Incorrect voltage ranges.
Old Jun 22, 2002 | 12:57 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Originally posted by qtiger
Can be solved, but you will lose accuracy UNLESS you employ a great deal of circuitry.
Whether or not it will be more accurate than a stock O2 sensor... :dunno:
You could use a stepdown transformer, but you lose a bit of your accuracy to inductive reactance You'd also have to engineer a bandpass filter and/or voltage spike suppression circuit to prevent really bad things from happening to your ecu.
Its a good idea overall in theory, but with some of the more powerful PEMS coming out, Wideband logging is already available and you can tune the fuel map right there without having to devise circuitry to fool the ecu. :thumbup:
JpEEzY3
Engine Swaps, Tech & Tuning
10
Aug 9, 2008 02:45 PM
TigerBun504
2
Jan 19, 2003 08:03 AM
EddieK
Sep 10, 2002 07:12 PM
Cosmo M3
Accord
5
Sep 2, 2002 12:40 PM
The G2 Racer
92+ Civic/EL & Del Sol
4
Aug 26, 2002 01:34 PM
