I need info on ross pistons 8.5.1
Old Feb 16, 2003 | 12:58 PM
t3/t4 hybrid's Avatar
t3/t4 hybrid
do any one know if I could use 1 gen turbo talon injectors on my b16a I used them on my zc turbo and it ran fine If you know let me know thanks.
Old Feb 16, 2003 | 01:46 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I'm assuming those are the same peak-and-hold 450cc DSM injectors that the 1st and 2nd gen turbo Eclipses have, so yes, you could run those on a B16A. You would have to make sure you have the right injector clips, and a resistor pack if your car originally had saturated injectors. If you're running a stock ECM, you would also need an AFC or some other way to trim fuel in order to idle and run the 450s.
