93 with ls vtec swap
Old Jan 19, 2009 | 02:07 PM
B-Rizzle's Avatar
B-Rizzle
Default 93 with ls vtec swap
just bought a 93 civic with a ls vtec swap in it. couldnt get it started for a while. put new plugs and wires, new distribitor and external coil, map sensor and it started. now its idling at 2000 and i cant figure out why?? i have been told maybe new throttle body gasket and intake manifold gasket? is this right?
Last edited by B-Rizzle; Feb 15, 2009 at 04:54 AM. Reason: dont have first problem
Old Jan 27, 2009 | 03:30 PM
ragecage92si's Avatar
ragecage92si
make sure fuel pump comes on. The nest way is to have someone listen at the gas cap ,and turn the key on.
**best**
Old Feb 1, 2009 | 12:58 PM
brandanintegra's Avatar
brandanintegra
what ecu are u runing ,an is it chiped an tuned right cause if not u realy needit too be , i have a runing ls vtec in my da integra i use a chiped p28
Old Feb 13, 2009 | 02:06 PM
B-Rizzle's Avatar
B-Rizzle
Default got it started
Originally Posted by B-Rizzle
just bought a 93 civic with a ls vtec swap in it. drove it 100 miles home, kinda idling funny until you hit 2000rpm. went out to start it, idled for second then died, wont start over now and idle. my boyfriend tried map sensor, and new throttle body. any ideas?
I finally got it started, put new plugs and wires, and new distribitor and external coil. but now it idles at 2000. i have been told new throttle body and intake manifold gaskets....??
