1985 prelude help
Old Jan 5, 2009 | 01:07 PM
85demonlude's Avatar
85demonlude
i put a 97 350 vortec in a 1978 ford courier im pretty sure i can put a 2002 motor in a 85 same make just different mounts an shit i can do ill post results let you know what is involved
Old Jan 10, 2009 | 11:09 AM
85demonlude
haha never mind id have to do all kinda customizing to put it in i think ill just put the b18c5 in not much less stock hp but the torque is pretty low only 127 dont like that but ill put a new intake an carb an shit on it should help me out there thanx for all the help an sorry for bein so hard headed
Old Jan 10, 2009 | 11:12 AM
85demonlude
i dont know i like the h22a blue top 97-01 also is the h swap as simple as the b swap
Old Jan 10, 2009 | 02:40 PM
85demonlude
iv notied that the jdm an usa motors differ by the location of pullies an all that shit they are on oppisite sides how will that affect me in puttin one in my usa 85 prelude
Old Jan 11, 2009 | 02:52 PM
jeff_falk2007's Avatar
jeff_falk2007
as i was telling you....the h22 is your best bet...i can point u in the right direction for mounts and axles if u want... www.raxles.com will supply the axles and Info@azracemachine.com will supply the mounts. the wiring will be up to you to do. power steering line on the pump will have to be modified to go with your existing line and donor pump. shifter and linkage will need to come from any 92-97 prelude or you will grind in reverse and 3rd and 4th other than those points its a straight bolt in affair.
