radiator fan question!
Old Dec 13, 2002 | 03:05 PM
civicon19s's Avatar
civicon19s
Default radiator fan question!
Hey guess, ive had a problem with my fan not cutting on, causing the car to run hot when standing still. First i ran a jumper wire to check the fan itself and it was fine. the fuse and relay appear to be fine so i did a continuity check on the switch which is right by the thermostat. It failed the test so now im wondering where do i find another switch? Does anybody have one? I need for a B series... thanks
Old Dec 13, 2002 | 04:38 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
There isn't a thermo-electric switch in the radiator itself?
Normally they don't have continuity unless the water is hot enough also.
-Harry
AIM: NDcissive
Old Dec 13, 2002 | 09:13 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
You can get the Spoon thermoswitch that switches the fan on at like 80 degrees C for like $75.
The OEM thermoswitch opens turns the fan on at 100 degrees C. You can get one for $24.64-32.87:
Old Feb 7, 2003 | 06:56 AM
dantastic's Avatar
dantastic
cx power!
ok... just wondering... if #11 is the thermo switch, whats #12??
Old Feb 7, 2003 | 08:43 AM
qtiger's Avatar
qtiger
Looks like a temperature probe to me...
Old Feb 7, 2003 | 12:25 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
12 is the temp sensor for the temp gauge in the dash, I believe.
Old Feb 7, 2003 | 12:29 PM
1stGenCRXer
On my car, #10 is the dash temp controller, #11 along with another sender in the radiator controll the fan, and I never could figure out exactly what #12 controlled, so it got removed so that I could add a mechanical water temp gauge.
-Harry
AIM: NDcissive
Old Feb 7, 2003 | 03:37 PM
dantastic's Avatar
dantastic
cx power!
yea... i have a gen1 b16a, and i dont have a fitting for a thermoswitch on the thermostat housing (#11)... and i think #10 is for the dash guage.... would it be ok to put the theroswitch where #12 is? or should i buy a new lower pipe spout with the housing in it??
Old Feb 9, 2003 | 06:19 PM
dantastic's Avatar
dantastic
cx power!
ok... well from the wiring diagram, i think #12 is for the thermo switch for the a/c system. since i took out the a/c, im just gonna plug in the thermo switch there
Old Feb 10, 2003 | 08:16 PM
undrgrndhaqer's Avatar
undrgrndhaqer
Mr. EG
im having a similar problem with my b18c. I installed a new aluminum dual radiator, plugged my old fan on to it and it never kicks on. Never. I don't know what it could be exactly causing the overheating. I know for sure there isn't a leak. Also, I just replaced the thermostat the same time I replaced the radiator. How do you go about checking continuity and exactly where is this switch that you keep talking about. Anyone have a real picture of it in their car? thanks for the extra help. I need to get the car down the street but can't.
