COLD starting
Old Dec 11, 2002 | 04:20 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Default COLD starting
We've got some cold weather up here in northeast PA. Past couple mornings, of course the car doesn't start right up like it does in warm weather. After seeing how the car starts the past couple mornings, I've wondered if theres a "better" way to start the car on such cold mornings. Example, would it be better to hold the key in the starting posisition untill it starts (2-4seconds) or hold it for a second... wait 3 seconds and then try again?
I recently got a Die Hard Gold put in and it's working fine. I'm just wondering if one method will put more strain and wear on the engine than the other. Suggestions?
I've also been trying to let the engine idle for at least 7-10mins while I get ready before taking off to work.
Old Dec 12, 2002 | 12:17 AM
VTECseoul's Avatar
VTECseoul
i love my wife's (y)
do not hold the key over, you'll only wear out your starter really quick. it just sounds like not enuff gas gettin to motor, get a tuneup. or bigger fuel injectors, better spark plugs & wires, etc.
Old Dec 12, 2002 | 04:28 AM
clickwir's Avatar
clickwir
well my plugs are Bosh Plat 4's, put them in less than 6months ago. Along with new wires at the same time. oil change isn't due for another 1000+. This is also 20 degree weather, most vechicles seem to have a little trouble starting in cold, right? Summer time with warm weather it takes less than a second to start. I've always assumed that colder weather makes that first start a bit more difficult.
