BURN IT! Only anwser I found. Can anyone help?
Old Dec 26, 2002 | 02:24 PM
6thGenCivic's Avatar
6thGenCivic
Just curious... which o2 code is it throwing, rich, lean, lazy...etc?
Old Dec 26, 2002 | 08:20 PM
Nickgsr1's Avatar
Nickgsr1
It's the second O2 sensor that is throwing the code and It is just not hooked up so it I have heard that it will just run off the frist o2 and that one is fine. The second 02 is just a double check of the frist to make sure it is working correctly.
Old Jan 18, 2003 | 09:49 AM
92b16vx's Avatar
92b16vx
The second o2 is there for a reason.Honda programmed the ecu to look for it.Your motor shouldn't hit vtec if it is rev limiting.This is a theory that I can check later on but,if your motor is looking for that 2nd o2 signal and not getting it it starts cutting back,because the obd tells it to.
