Cams
Old Dec 12, 2002 | 09:22 AM
93Integra's Avatar
93Integra
Originally posted by MrFatBooty
I believe the part numbers are cast/stamped into the cam somewhere.
Look for these codes:
PR3 - USDM B16/B17
P30 - JDM B16
P72 - GSR
P73 - R
I've got my friends ITR head and cams (or atleast he says they are ITR) laying around at my house and I checked them out and I don't see anything stamped on the cams. When I looked at the head it had PR3-4 stamped on it, so what what is the stamp for ITR, is it P73 or PR3-4? Very confused! Is P73 the code for the ITR cams, b/c you were talking about cams.
Old Dec 12, 2002 | 10:15 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The ITR head uses the same casting as the B16, hence the PR3. My B17 also has PR3 stamped on the head.
The ECU, pistons and cams are specific to each exact engine so they have unique codes. I don't know if there are actually numbers stamped/cast on the cams but those are the codes.
