engine prob
Old Dec 2, 2002 | 08:48 PM
Phat8186's Avatar
Phat8186
Default engine prob
my engine is making a whistling noise when ever i accelerate in every gear, can anyone tell me what this may be. I have never heard the noise until three weeks ago.please help it is qiet annoying
Old Dec 2, 2002 | 09:24 PM
dubcac's Avatar
dubcac
I
Possibly your intake. It typically does it at around 1/4 throttle.
Old Dec 2, 2002 | 10:03 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Check for vac/exhaust leaks.
Old Dec 3, 2002 | 08:36 AM
Phat8186's Avatar
Phat8186
what do you mean that it could be my intake at 1/4 throttle
Old Dec 3, 2002 | 09:52 AM
Phat8186's Avatar
Phat8186
if it is my intake what should i do get a new one
Old Dec 3, 2002 | 10:07 AM
cvc2k's Avatar
cvc2k
"intake at 1/4 throttle" = pressing on the gas 1/4 way down, sucking more air in the intake
Get a friend to diagnose the problem. Put it in neutral, and let the friend give it some gas while you try to find out where it is coming from. If it is the intake, you can probably just fix it with some superglue or something :-p (ghetto fix). (intake should never get too hot anyway)
If you still cant' find the leak, try spraying some brake cleaner around. The RPM should jump up if that stuff find a way into the engine. Just don't aim cleaner sprayer at the air inlet :-p
Hope that helps..
Old Dec 3, 2002 | 06:04 PM
aut0tek's Avatar
aut0tek
I bet it's the Intake... if u floor the throttle does the whistling stop?
Old Dec 3, 2002 | 06:11 PM
Phat8186's Avatar
Phat8186
as a matter afact when i floor it the whistle comes to a stop. it only does it as i am accelerating
Old Dec 11, 2002 | 05:04 PM
Nickgsr1's Avatar
Nickgsr1
Something else you can check is the transmission fluid. When the trans get low it kinda makes a car sound like it is supercharged. Usually only does it when u are accelerate and gets quiter in higher gears. A real easy way to check this is to put it in netural and rev up if it whistles it not the trans. Then put it in 1st and start to drive and if it is whistling I would check the fluid.
Old Dec 11, 2002 | 05:53 PM
Phat8186's Avatar
Phat8186
if i rev it in neutral it doesnt whistle. I will do it how ever when I am in 1st gear or any other gear. thanks for the info i will check the tran fluids though
