Help Needed....I'm stalling out and don't know what to do
Old Aug 29, 2008 | 08:59 AM
a_ruggiero's Avatar
a_ruggiero
Default Help Needed....I'm stalling out and don't know what to do
I ve a 92 automatic integra and the problem started 2 days ago. I'll be driving for about 10 to 15 mins and then my car would start to bog out like its misfiring than catch again, it will stall shortly after and i'd have to put it in nuetral to start it up again. It will also stall when i got to stop. I have no idea what the problem is can somebody please help me? Thanks.
Old Sep 22, 2008 | 10:30 PM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Fuel filter maybe?
Old Dec 13, 2009 | 05:17 PM
tegdriver4life's Avatar
tegdriver4life
might be the fuel pump on the way out.:af:
Old Jan 3, 2010 | 02:23 PM
Redline96LX's Avatar
Redline96LX
check the most basic stuff first before going to a shop to have em diagnose it. Check the FITV. The fast idle thermo valve controlls the car's idle (i'm only guessing as it can take 10-15 minutes to warm up, if you drive ligjhtly and its freezing out.) Have the distributor checked for the contacts (the cap and rotor can be checked by removing the cap's phillips headed screws. could also be the plugs or injectors, so feel free to add some dry gas to the fuel, if the car is either higher in mileage or has sat for any extended period of time.
