need HELP ASAP "fuel"
Old Nov 28, 2002 | 11:32 AM
acura69gsr's Avatar
acura69gsr
Default need HELP ASAP "fuel"
i put an AEM fuel rail on, and an AEM fuel reg. .........on my 2000 teg "GSR" now it doesn't want to start up right????? what do i need to do the fuel pres. is set to stock psi. i have the fuel press gauge hooked up too? b/c it will not start up at first it made the cel come on and its reading code 71 misfire in cyl. #1 how do i fix this anything will help me thanks everybody
Old Nov 28, 2002 | 05:27 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Are you running the right orifice(h: ) in the AEM FPR? What's your fuel pressure reading with the rail pressurized? Are your injectors connected properly?
Old Nov 29, 2002 | 05:05 PM
acura69gsr's Avatar
acura69gsr
the car runs fine it will not start right i don't know what to do to it
Old Nov 29, 2002 | 08:14 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Old Nov 30, 2002 | 07:54 AM
acura69gsr's Avatar
acura69gsr
i'm at stock psi's man its like at 38-43 something like that the injectors are hooked up right.......
Old Nov 30, 2002 | 12:38 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Hold a screwdriver up to the injector for cyl#1 and put your ear against the handle. See if you can hear the injector clicking as it cycles.
Old Dec 1, 2002 | 08:45 AM
acura69gsr's Avatar
acura69gsr
ok i'll see what it does man
