95 integra ls engine?
Old Nov 16, 2002 | 08:37 PM
94typerhb's Avatar
94typerhb
Default 95 integra ls engine?
i have a 95 integra ls, and i want to put it in to my 91 ls. all i have is the 91 ls shell and tranny and axelor cv boot, and the 95 ls longblock. what harness, engine mount, kits would i need.
thanx for any inputs, i greatly appreciate it.:thumbup:
Old Nov 17, 2002 | 11:48 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You need the parts out of a '91 Integra. The motors are essentially the same, so if you were to install it as if it was a '91 motor (i.e. '91 mounts, harness and ECU) then it should work just fine.
Old Nov 17, 2002 | 08:15 PM
94typerhb's Avatar
94typerhb
so do i use a cable tranny, will it fit right in? being that the 95 long block is a hydro, and the car is a cable. thanx for replying
Old Nov 18, 2002 | 04:37 PM
SmOkIneLf's Avatar
SmOkIneLf
well since its a hydro you might have ot get a hydro cable conversion kit but i am not too sure on that one anyone wanna help me out here?
Old Nov 18, 2002 | 06:57 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Your cable tranny will bolt up. I wouldn't recommend trying to convert from cable to hydro. They make hydro to cable conversion kits, but I've never heard of a hydro to cable kit.
Old Nov 19, 2002 | 07:43 PM
94typerhb's Avatar
94typerhb
thanx
Old Nov 19, 2002 | 09:56 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Me personally, I like a cable clutch more than a hydraulic clutch. It gives better feel but a hydraulic is a lighter and easier to drive. I could go on a rant about that but I shall refrain.
Anyway, I've seen kits out there to do some sort of cable<==>hydro conversion but I forget if it was to put a hydro transission in a cable car, or to put a cable transmission in a hydro car.
Old Nov 19, 2002 | 10:14 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
http://www.hasport.com/Products/Moun...nt%20EGBCC.htm
The hydro>>cable conversion kits allow you to put cable trannies into hydro cars. It basically repositions the slave cylinder to engage the release fork ont he cable tranny.
Old Nov 20, 2002 | 12:01 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
OK I just re-read this topic and he's talkin about using a '91 transmission in a '91 car with a '95 longblock. In that case the transmission will be fine, and the motor will most definitely bolt up to the transmission. Only thing you have to do is make sure you use '90-'91 Integra clutch parts. The '92-'01 cars have a larger flywheel and clutch.
Old Nov 20, 2002 | 03:00 PM
SmOkIneLf's Avatar
SmOkIneLf
sorry i guess i got the hydro cable conversion thing mixed up :doh:
