Best engine for a 6th gen sedan?
Old Nov 14, 2002 | 02:08 PM
6thGenCivic's Avatar
6thGenCivic
Default Best engine for a 6th gen sedan?
Just curious of all of your opinions and some advice on what would result in the most bang for the buck as far as hybrid swaps in a 97 LX w/ the conversion from auto to man.. Emissions tests are not an issue so I was curious as to the difficulty in swapping in an OBDI. I am looking to do a swap that is fairly inexpensive but I am an automotive technology student, a certified ASE tech and have access to tools and equip.(liftsetc...) so difficulty can be a little on the tough side but I have never done a honda swap although i have heard that that they are comperativley easy, similar to a SB chevy swap. Any advice or suggetions would be appreciated. PEACE
Old Nov 14, 2002 | 05:03 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You're going to some great lengths with an auto... It almost calls for a new car, but if you have the time and that patients (and especially the $$) I commend you.
This is one of the most asked questions on this board so you could do a search for compatible engines and find a bunch of info.
you can swap any B-series engine (B16A2, B16A3, B16B, B18A, B18C1, B18C5, B18C) using stock mounts and it will slip right in.
You can also put H-series engines in with a HASport mount kit.
As for OBD1, I just used an OBD2 engine and harness with an OBD1 ECU and all is well.
I'm not too experienced with auto/manual conversions, but there was just a thread open on it in the '92+ civic forum. Do a search on that too.
Hope it helps.
Old Nov 15, 2002 | 12:55 AM
taylormadem5's Avatar
taylormadem5
Best engine i would say would have to be a JDM B18C1 with an LSD. you get 180hp, an LSD, and you can rev it just as high as a b16 and get more hp out of it. Thats just my opinion.
Old Nov 15, 2002 | 11:50 AM
speed614's Avatar
speed614
Civic GSR Driver
Dont forget about the option of the B20 too. Thats one torquey mofo.
Old Nov 16, 2002 | 05:18 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
After doing some research, if you have the money to spend, the H22A-R is the best way to go.
Performance
H22A-R
220hp @ 7200 rpm
163lb/ft @ 6500 rpm
13.75@100.8mph
Now that time is in a 4gen Civic Hatch but you could probably expect similar times.
Old Nov 16, 2002 | 11:12 AM
DB7 2.0's Avatar
DB7 2.0
Banned
Performance
H22A-R
220hp @ 7200 rpm
163lb/ft @ 6500 rpm
13.75@100.8mph
a 6th gen civic SEDAN will not get similar times to a 4th gen HATCH
