GSR swap times
I was just wondering what all you people with GSR swaps into your coupes were running in the 1/4 mile. Also what your raceweight was, and anything else you wanna put. I got my swap all done but have yet to run it at the track. Im expecting low 15s hopefully.
well my nearly stock GSR runs 15 flat, thats with the teg body too...my bros 93 ex body weighs a couple hundred pounds lighter so id assume at least high 14's...my buddies got a 94 hatch with a b18c and runs high 13's
A HATCH W/ A GSR WILL RUN MID 15'S YOU SWEAR LIKE A STOCK HONDA MOTOR GOING TO BE LIKE A TEG WITH LOW BOOST. THATS BULL BUT THEN AGAIN I LIVE IN THE MOUNTAINS AND MY TIME HERE IN MY CITY WAS A 14.92 AND WHEN I WENT TO CALI I RAN A 14.1 THE REASON I GOT A LOWER TIME IN CALI WAS THE SEA LEVEL AND AIR PRESSURE SO IF CHIGAGO HAS A LOW SEA LEVEL THEN MAY BE BUT JUST DONT EXPECT 15,S ON A STOCK HONDA MOTOR. DONT GET ME WRONG YOULL BE A LITTLE QIUCK MOTHER f***ER BUT YOU NOT GOING TO BE ALL FASTEST MAN ON THE TRACK WITH A STOCK MOTOR SWAP
:stupid: Don't listen to him, he's full of BS.
Stock Civic Si will run 15.1-15.4 with the B16, so why isn't a 15 sec flat time not seem possible with a skilled driver and the extra torque of the B18?
When you do run shed all your extra weight. I know the passenger seat and back seat bottom come out easily. Good luck and post results after you run.
Well ill take my subs and spare tire out, i dunno about the seats or anything. But i guess ill see. It will be a while before i make it to the track because they are all closed down for winter. But ill post once they open back up, or i find one that hasnt closed yet.
stock si doesnt get anywhere near low 15s. it's a mid 15 second car, 15.6-15.8 with good driving. stock gsr nets a 15.4-15.6 with good driving, a stock prelude will get a 15.2-15.4.
15.1 with a stock Si. not likely.
... a civic with a GSR motor(b18c1) should run about high to mid 14's i would say.
