o2 sensor
Old Nov 11, 2002 | 09:59 AM
crash's Avatar
crash
Default o2 sensor
Does anyone know where i can get an oxygen sensor for the exhaust manifold, on my 95 gsr for a good price. I called the acura dealer here and they want $231.00 for it.
Old Nov 11, 2002 | 10:22 AM
lttletimmy's Avatar
lttletimmy
go to autozone, get a bosch for $40.
Old Nov 11, 2002 | 10:32 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
you can splice a universal 4-wire O2 onto your stock harness.
Old Nov 11, 2002 | 07:34 PM
crash's Avatar
crash
can someone tell me how to replace the o2 sensor in my exhaust manifold, on my 95 gsr, ive never replaced the o2 sensor before?
tia
Old Nov 11, 2002 | 07:47 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It's easier to do with the manifold off, but it's not absouletly necessary to remove it. You will, however, need an O2 sensor socket which has a slot for the wires to slip thru. Disconnect the O2 harness at the plug, then remove it with the socket. If it's been there for a while, it may take some muscle to get it off, which is why it's easier to do off the car, but it should help if you soak it with some WD-40 or liquid wrench, etc. If you're getting a new stock one, just reverse the process. If not, then splice your new universal O2 onto the plug from the old one and put it on.
Old Nov 11, 2002 | 08:00 PM
crash's Avatar
crash
thanx that should help.
