Rod bearings for ITR
Old May 10, 2008 | 11:41 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Rod bearings for ITR
I have a B18c6 with a damaged bearing, the crank looks fine so i just need to replace the bearing.
It had a ACL 0.25 bearing in it, can anyone please tell me which honda OEM bearing colour equates to that?
I can order the ACL bearings from the USA, but they take over a week to get to me in the UK so i'd rather just order them from the dealer here in the UK.
Thanks for any help
Colour codes etc for your referance
Conrod Bearing Set
1.510-1.507 mm 0.0594"-0.0593" BLUE
1.507-1.504 mm 0.0593"-0.0592" BLACK
1.504-1.501 mm 0.0592"-0.0591" BROWN
1.501-1.498 mm 0.0591"-0.0590" GREEN
1.498-1.495 mm 0.0590"-0.0589" YELLOW
1.495-1.492 mm 0.0589"-0.0587" PINK
1.492-1.489 mm 0.0587"-0.0586" RED
GSR/ITR Rod bearings
13211-P72-003 BLUE
13212-P72-003 BLACK
13213-P72-003 BROWN
13214-P72-003 GREEN
13215-P72-003 YELLOW
13216-P72-003 PINK
13217-P72-003 RED
Thanks for any help
Old May 10, 2008 | 02:51 PM
B16a2VTIguy
Built B16a
a honda bearing wont equate to this size will it?
As 0.25mm is 10 thou
So even the blue bearing it will be 7 thou out, right?
