another ls/vtec vs turbo ?
Old Nov 3, 2002 | 03:56 PM
acurars's Avatar
acurars
Default another ls/vtec vs turbo ?
i've heard that ls/vtec is unreliable but what about turbo? what do you guys think is better for a daily driver im leaning more towards turbo any input will help? its on a 94 teg rs 118,000 miles
Old Nov 3, 2002 | 03:58 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Both can be reliable. It depends on what you do specifically, rather than some grand classification for a general procedure which can be performed any number of different ways.
Old Nov 3, 2002 | 04:02 PM
qtiger's Avatar
qtiger
Takes money for either one to be reliable.
Old Nov 3, 2002 | 04:06 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Either setup, done correctly should have little to no reliability issues. Problems arise when you try to skimp in certain areas, don't use the right components, or fail to tune properly. That said, I would boost your B18B properly, and then add VTEC later on if your funds allow.
Old Nov 3, 2002 | 05:12 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
I'd consider swapping because with that high of miles, turbo might be unreliable on the stock internals. As long as you do everything by the book, both with be reliable, but in the end I think the LS/VTEC will please you more.
