2000 ITR head on 1st gen b16?
Old Oct 30, 2002 | 04:47 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default 2000 ITR head on 1st gen b16?
What would I have to do to put a 2000 integra type-r head on a 1st gen b16 block? it will be going into a 95 hatch.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Oct 30, 2002 | 06:17 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
It bolts on. The ITR head is essentially a B16 head with a mild port/polish job done from the factory, plus the more aggressive cams and valve springs.
Old Oct 30, 2002 | 07:44 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Hey mikey, are there any sensor/plug differences headwise between OBD-II and OBD-I/non-OBD?
Old Oct 30, 2002 | 07:51 PM
Import-Tooner
skoooooie!
thats my main concern.
SKOOIE!!!
Old Oct 31, 2002 | 05:00 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I think there is a slight harness difference, which is mainly due to the knock sensors and electronic VSS on the OBD-II cars. I'd have to do some searching to verify though, I'm running from memory right now.
-Harry
AIM: NDcissive
Old Oct 31, 2002 | 12:38 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Doesn't the VSS run off of the transmission?
My guess on the knock sensor is that since this is in a '95 hatch he's running a chipped P28 which can't read the KS anyway.
Old Oct 31, 2002 | 12:54 PM
1stGenCRXer
It does, but that would be a wiring harness difference
Old Oct 31, 2002 | 01:09 PM
qtiger's Avatar
qtiger
There's a couple extra sensors, but most of them are on the block, not the head. Knock will be your only concern.
Old Oct 31, 2002 | 03:01 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Isn't the knock sensor in the block?
