Timing on a 91 b18 integra
Old Mar 19, 2008 | 04:24 PM
flatblacktegra's Avatar
flatblacktegra
Default Timing on a 91 b18 integra
im not sure all what to do to get the timeing right, i put the cams pointing up and lined up trhe lines on the block and it wont fire up!!
Old Mar 20, 2008 | 06:19 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Which line on the crank pulley? The single white line is the TDC mark and what you want to line the cams up with.
I would suggest looking at the procedure in a shop manual before you end up bending a valve.
Old Mar 23, 2008 | 03:07 PM
flatblacktegra
yeah i was talkin about the white line!!
